Ah yes, a unique keys error on insert would cause all pending SQL to rollback. Makes sense why it might fail without and succeed with the DISTINCT.
Find, Review, and Engage with Higher Education-focused solution providers, products, and services using the
Sent: 10-28-2025 10:20 AM
Subject: Need help with Callable SQL for Equation Engine
I added it below (highlighted) and then it worked.
INSERT INTO PS_UC_TRNCOMP_ATTR
(INSTITUTION, TRNSFR_SRC_ID, COMP_SUBJECT_AREA, EFFDT, TRNSFR_EQVLNCY_CMP, CRSE_ATTR, CRSE_ATTR_VALUE)
SELECT DISTINCT B.INSTITUTION,
B.TRNSFR_SRC_ID,
B.COMP_SUBJECT_AREA,
B.EFFDT,
B.TRNSFR_EQVLNCY_CMP,
'RD',
'MC'
FROM PS_TRNSFR_FROM B
WHERE (B.EFFDT =
(SELECT MAX(B_ED.EFFDT) FROM PS_TRNSFR_FROM B_ED
WHERE B.INSTITUTION = B_ED.INSTITUTION
AND B.TRNSFR_SRC_ID = B_ED.TRNSFR_SRC_ID
AND B.COMP_SUBJECT_AREA = B_ED.COMP_SUBJECT_AREA
AND B_ED.EFFDT <= SYSDATE)
AND B.TRNSFR_SRC_ID IN ('16001051','16007436')
AND NOT EXISTS (SELECT DISTINCT C.TRNSFR_SRC_ID
FROM PS_UC_TRNCOMP_ATTR C
WHERE C.EFFDT =
(SELECT MAX(C_ED.EFFDT) FROM PS_UC_TRNCOMP_ATTR C_ED
WHERE C.INSTITUTION = C_ED.INSTITUTION
AND C.TRNSFR_SRC_ID = C_ED.TRNSFR_SRC_ID
AND C.COMP_SUBJECT_AREA = C_ED.COMP_SUBJECT_AREA
AND C_ED.EFFDT <= B.EFFDT)
AND C.TRNSFR_SRC_ID = B.TRNSFR_SRC_ID
AND C.COMP_SUBJECT_AREA = B.COMP_SUBJECT_AREA
AND C.TRNSFR_EQVLNCY_CMP = B.TRNSFR_EQVLNCY_CMP))
Sent: 10/28/2025 10:12:00 AM
Subject: RE: Need help with Callable SQL for Equation Engine
So you put the DISTINCT on the SELECT in the main part of the SQL?
Sent: 10-28-2025 09:50 AM
Thanks, Dan.
I just got it to work and came back to let you know I was missing DISTINCT. I had 1 value that was duplicated.
So I needed SELECT to be SELECT DISTINCT.
Sent: 10/28/2025 9:38:00 AM
Hello Dana,
Try the following SQL to see if it does anything (also :
SELECT
A.INSTITUTION,
A.TRNSFR_SRC_ID,
A.COMP_SUBJECT_AREA,
A.EFFDT,
A.TRNSFR_EQVLNCY_CMP,
'RD',
'MC'
FROM PS_TRNSFR_FROM A
WHERE
A.EFFDT = (
SELECT MAX(A_ED.EFFDT)
FROM PS_TRNSFR_FROM A_ED
WHERE A_ED.INSTITUTION = A.INSTITUTION
AND A_ED.TRNSFR_SRC_ID = A.TRNSFR_SRC_ID
AND A_ED.COMP_SUBJECT_AREA = A.COMP_SUBJECT_AREA
AND A_ED.EFFDT <= TRUNC(SYSDATE)
AND A.TRNSFR_SRC_ID IN ('16001051','16007436')
AND NOT EXISTS (
SELECT 1
FROM PS_UC_TRNCOMP_ATTR B
WHERE B.INSTITUTION = A.INSTITUTION
AND B.TRNSFR_SRC_ID = A.TRNSFR_SRC_ID
AND B.COMP_SUBJECT_AREA = A.COMP_SUBJECT_AREA
AND B.TRNSFR_EQVLNCY_CMP = A.TRNSFR_EQVLNCY_CMP
AND B.EFFDT = (
FROM PS_UC_TRNCOMP_ATTR B_ED
WHERE B_ED.INSTITUTION = B.INSTITUTION
AND B_ED.TRNSFR_SRC_ID = B.TRNSFR_SRC_ID
AND B_ED.COMP_SUBJECT_AREA = B.COMP_SUBJECT_AREA
AND B_ED.EFFDT <= A.EFFDT
I noticed that you have a DISTINCT in the DOES NOT EXIST subquery. In an EXISTS or NOT EXISTS subquery, the database only cares whether at least one row matches the condition (TRUE or FALSE) and never looks at the actual values returned by the SELECT list. I am not saying that it is the cause of the issue. How is the equation set up?
Sent: 10-28-2025 09:24 AM
Do you guys think it could be security related?
Sent: 10/28/2025 9:19:00 AM
I'm trying to do an insert into a UC table. PS Query select gives me 1398 rows.
This is the SQL from PS Query.
SELECT A.INSTITUTION, A.TRNSFR_SRC_ID, A.COMP_SUBJECT_AREA, TO_CHAR(A.EFFDT,'YYYY-MM-DD'), A.TRNSFR_EQVLNCY_CMP, 'RD', 'MC'
(SELECT MAX(A_ED.EFFDT) FROM PS_TRNSFR_FROM A_ED
WHERE A.INSTITUTION = A_ED.INSTITUTION
AND A.TRNSFR_SRC_ID = A_ED.TRNSFR_SRC_ID
AND A.COMP_SUBJECT_AREA = A_ED.COMP_SUBJECT_AREA
AND NOT EXISTS (SELECT DISTINCT B.TRNSFR_SRC_ID
WHERE B.EFFDT =
(SELECT MAX(B_ED.EFFDT) FROM PS_UC_TRNCOMP_ATTR B_ED
AND B_ED.EFFDT <= A.EFFDT)
AND B.TRNSFR_EQVLNCY_CMP = A.TRNSFR_EQVLNCY_CMP))
I modified it to do the insert into the UC table and it's running with no errors, but not inserting the data. ??? Do you guys see something that I don't? I don't use this table, I'm doing it for a friend. I was able to update the UC table. Some records existed and they wanted those values changed. That one worked.
Here is my INSERT. It's chunking fine. And I put in a message statement and it's telling me it's inserting 0 rows. I query the data, nothing is being inserted. It runs and does nothing.
A.TRNSFR_SRC_ID,
A.EFFDT,
'RD',
'MC'
WHERE (A.EFFDT =
WHERE B.EFFDT =
