  • 1.  Pivot Grid not calculating correctly for Grade Distribution
    Posted 08-05-2025 06:32 PM
    Hello all,
    I'm designing my 2nd pivot grid, and the counts on the pivot grid are not the same as the raw data.  The query I have is a grade distribution by division, term, subject, catalog, instructor, session, and mode.  I then threw in the section number, hoping that would solve the problem. The SQL is below.
    An example of one that is correct is PSY on the pivot grid has 1025 grades, which matches my raw data.  But then ECON has 1002 for a count on the pivot grid, but the raw data is 873.  I thought that it was a meeting pattern that was duplicating grades, so I limited the query to meeting pattern = 1, but then other numbers were different on other subjects.  I also just noticed that the count for the term has a total of 8514, but the raw data is 8159.
    Has anybody encountered their raw data being one number, but the pivot grid calculates a different number?  Any suggestions on how I can get the pivot grid to calculate correctly?
    Thank you!
    Lee
    SELECT DISTINCT A.EMPLID, C.DESCR, B.SUBJECT, B.CATALOG_NBR, E.NAME, B.SESSION_CODE, A.CRSE_GRADE_OFF, B.INSTRUCTION_MODE, B.CLASS_SECTION
      FROM PS_STDNT_ENRL A, PS_CLASS_TBL B, PS_TERM_TBL C, PS_CLASS_INSTR_VW D, PS_PEOPLE_SRCH E
      WHERE ( C.STRM = A.STRM
        AND C.ACAD_CAREER = A.ACAD_CAREER
        AND C.INSTITUTION = A.INSTITUTION
        AND E.OPRCLASS = 'HCPPALL'
        AND ( A.ACAD_CAREER = 'UGRD'
         AND A.INSTITUTION = 'TMCC1'
         AND A.STRM = '2252'
         AND A.STDNT_ENRL_STATUS = 'E'
         AND A.GRADING_BASIS_ENRL NOT IN ('NON','NOG','TEC')
         AND A.ENRL_STATUS_REASON IN ('ENRL','EWAT','WDRW')
         AND A.ACAD_CAREER = B.ACAD_CAREER
         AND A.INSTITUTION = B.INSTITUTION
         AND A.STRM = B.STRM
         AND A.CLASS_NBR = B.CLASS_NBR
         AND B.SESSION_CODE = A.SESSION_CODE
         AND B.CRSE_ID = D.CRSE_ID
         AND B.CRSE_OFFER_NBR = D.CRSE_OFFER_NBR
         AND B.STRM = D.STRM
         AND B.SESSION_CODE = D.SESSION_CODE
         AND B.CLASS_SECTION = D.CLASS_SECTION
         AND B.ACAD_GROUP IN ('T1540','T154U')
         AND D.INSTR_ROLE = 'PI'
         AND E.EMPLID = D.EMPLID
         AND E.NAME_TYPE = 'PRI' ))
  • 2.  RE: Pivot Grid not calculating correctly for Grade Distribution
    Posted 08-07-2025 12:22 PM
    Hello all,
    An update on this.  It looks like the "Distinct" is not obeying when the pivot grid is generating.  Also, when I do a "Count" with the Distinct on inside the normal query in the fields tab, it isn't calculating correctly.  Here is the SQL when I do the count.  Do you think this is a bug or is there a good way to get around this issue?
  • 3.  RE: Pivot Grid not calculating correctly for Grade Distribution
    Posted 08-07-2025 01:23 PM
    Hi Lee,
    I'll preface by saying that these tables are bit outside my wheelhouse, and I have 0 experience working with pivot grids - pivot tables in Excel have been sufficient for my business needs so far ��.
    That said, I think the issue that you are seeing is a universal 'gotcha' that often surfaces when working with aggregates in PS Query and SQL; Any key fields that aren't appropriately accounted for will create inflated numbers in your aggregates.
    In your case, my hunch is that PS_CLASS_INSTR is the culprit. If you run your SQL again but without tables D and E, does that give you the expected number?
    If so, then I think you will need to take a look at the key fields, CLASS_MTG_NBR, and INSTR_ASSIGN_SEQ. They will need to be set to some criteria, or returned in your SELECT and GROUP BY statements.
    Hopefully that helps!
  • 4.  RE: Pivot Grid not calculating correctly for Grade Distribution
    Posted 08-07-2025 01:59 PM
    You are right, the D table is the culprit.  When I add that record, that is when I get more rows to be "counted" upon. I did find the pivot grid in PS that has "Count Distinct", but I can't get that to work either! First screenshot.
    I did find a PP from 2006 that says I can write an expression.  But I am trying to avoid expressions because Pivot Grids in PS don't like them.  I can go after a view and try to build my Pivot Grid from the view. But I'm trying to build this pivot grid without any help from the outside, just to challenge myself, and this isn't a priority.  2nd screenshot and attaching the PP.
    I'm playing with Subqueries to see if I can get that to work to make it distinct, but I think I've worn out my brain at this time and need to get some lunch. Just in case you are interested in Pivot Grids in PS, attaching that PP too from 2017.
    First Screenshot:
    Second Screenshot:
    Thank you!
    Lee
    Lee Raubolt, M.S.
    Associate Director of Admissions & Enrollment Services
    7000 Dandini Blvd.
    RDMT 319
    Reno, NV 89512 USA
    775-674-7624
    On Thu, Aug 7, 2025 at 10:25 AM Jeffrie Brooks via Higher Education User Group <Mail@heug.org> wrote:
    Hi Lee, I'll preface by saying that these tables are bit outside my wheelhouse, and I have 0 experience working with pivot grids - pivot tables in...
    Post New Discussion
    Re: Pivot Grid not calculating correctly for Grade Distribution
    Reply to Thread
    Aug 7, 2025 1:23 PM
    Jeffrie Brooks
    Hi Lee,
      Reply to Community   Reply to Sender via Email   View Thread   Recommend
    You are receiving this notification because you followed the 'Pivot Grid not calculating correctly for Grade Distribution' message thread. If you do not wish to follow this, please click here.
    Update your email preferences to choose the types of email you receive
    Unsubscribe from all participation emails
    Alliance 2026 | March 8-11, 2026 | Orlando, FL
    Sent: 8/7/2025 1:23:00 PM
    Subject: RE: Pivot Grid not calculating correctly for Grade Distribution
    Hi Lee,
    Sent: 8/7/2025 12:22:00 PM
    Hello all,
  • 5.  RE: Pivot Grid not calculating correctly for Grade Distribution
    Posted 08-12-2025 02:25 PM
    Just in case somebody needs it, I got this expression to calculate correctly:
    Count (DISTINCT A.EMPLID)
    Looks like when you use the distinct checkbox, it puts it on the outside.
    Lee
