Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
  • 1.  Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 07-30-2025 12:08 PM
    Hello all,
    For who attended and have additional questions, comments, and/or insights to this webinar, please add them here.  I will get my scramble expression out there today.
  • 2.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 07-30-2025 12:21 PM
    Hello all,
    Here is the link to the Idea Labs that asks for way to move the fields around more efficiently in Composite Query: https://community.oracle.com/mosc/discussion/4581685/field-reordering-improvement-for-composite-query.
  • 3.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 07-31-2025 03:45 PM
    Hello all,
    As promised, I am giving you all the method by which I "scramble" PII data. Attached you will find a document on using STANDARD_HASH and DBMS.RANDOM to do so.
  • 4.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 08-04-2025 12:43 PM
    Thanks for putting this together,  Dan.  Great trick!  Confirmed that these work in Query Manager Expressions too (in our install, anyway).
    Kendall Vance
    IT Technical Associate for Financial Aid Reporting
    Northern Illinois University
  • 5.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-08-2025 01:15 PM
    I just watched the recording of the webinar...thanks for providing this!
    You mentioned the Q&A from the session would be available... if it is posted on HEUG I haven't been able to find it.
    Thanks again!
    Susan
    Susan Gutierrez
    FA and SF Functional Analyst
    Sonoma State University
  • 6.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-09-2025 06:33 AM
    Hey Susan - I think in the end, we did not capture the individual questions from the Q&A, but I can check with Tesha about that.  You can review the PS Query / SQL library to see if there are resources there which might prove helpful.  That library can be found here - PS Query & SQL Library.
    Also, please feel free to post questions here - I know Dan and I will be happy to answer any questions we can, and there were several folks on the call who had experience with this tool.
    Take Care!
  • 7.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-09-2025 10:01 AM
    Hello Susan,
    Here is the out from the Q&A.  I tried to clean it up some from the CSV that was sent to me.
    xlsx
    Webinar Q&A Output.xlsx   16 KB 1 version
  • 8.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-10-2025 01:29 PM
    Thanks to your wonderful webinar, I was able to create a composite query for our scholarship coordinator that has one row for each scholarship awarded with both Fall disbursement and Spring disbursement data in one row...yay!
    One issue I haven't figured out is what to do with scholarships that have more than one disbursement per term. The output of my current composite query is producing 4 rows instead of one...one row for the first Fall disbursement with the first Spring disbursement data, a second row for the first Fall disbursement with the second Spring disbursement data, a third row for the second Fall disbursement with the first Spring disbursement data, and a fourth row for the second Fall disbursement with the second Spring disbursement data.
    Ideally, there would be a column in the output for each of those second disbursements...all on one row.
    Here is the SQL:
    SELECT DISTINCT Q1."1EMPLID",
        Q1."1NAME",
        Q1."1EMAIL_ADDR",
        Q1."1TEM_TYPE",
        Q2."4IT_DESCR",
        Q2."4FUND_CODE",
        Q2."4DEPTID",
        Q3."2STRM",
        Q3."2DISB_ID",
        Q3."2OFF_BAL",
        Q3."2ACC_BAL",
        Q3."2DISB_BAL",
        Q3."2ACAD__PLAN",
        Q3."2ACAD_CAREER",
        Q4."3STRM",
        Q4."3DISB_ID",
        Q4."3OFF_BAL",
        Q4."3ACC_BAL",
        Q4."3DISB_BAL",
        Q4."3ACAD_PLAN",
        Q4."3ACAD_CAREER"
    FROM
      (SELECT DISTINCT A.EMPLID AS "1EMPLID",
        B.NAME AS "1NAME",
        C.EMAIL_ADDR AS "1EMAIL_ADDR",
        A.ITEM_TYPE AS "1TEM_TYPE",
        A.ACAD_CAREER AS "1ACAD_CAREER",
        A.INSTITUTION AS "1INSTITUTION",
        A.AID_YEAR AS "1AID_YEAR"
      FROM PS_STDNT_AWARDS A,
        (PS_SCC_PERDATA_QVW B LEFT OUTER
    JOIN
         PS_SCC_EMAIL_QVW C
    ON
         B.EMPLID = C.EMPLID AND C.E_ADDR_TYPE = 'OCMP' )
      WHERE ( A.INSTITUTION = 'SOCMP'
         AND A.AID_YEAR = '2026'
         AND ( A.ITEM_TYPE BETWEEN '800000000000' AND '800000099999'
         OR A.ITEM_TYPE IN ('840000004500','840000004501','840000005300'))
         AND A.EMPLID = B.EMPLID
         AND A.OFFER_AMOUNT > 0) ) Q1
    JOIN
        ( SELECT B.DESCR AS "4IT_DESCR",
        E.FUND_CODE AS "4FUND_CODE",
        E.DEPTID AS "4DEPTID",
        B.SETID AS "4SETID",
        B.ITEM_TYPE AS "4ITEM_TYPE",
        B.EFFDT AS "4EFFDT",
        B.EFF_STATUS AS "4EFF_STATUS",
        C.STRM AS "4STRM",
        C.EFFDT AS "4GL_EFFDT",
        C.EFF_STATUS AS "4GL_EFF_STATUS"
      FROM PS_ITEM_TYPE_1_TBL A,
        PS_ITEM_TYPE_TBL B,
        PS_GL_INT_DT_TBL C,
        PS_GL_INTERFACE E
      WHERE ( B.SETID = A.SETID
        AND B.ITEM_TYPE = A.ITEM_TYPE
        AND C.SETID = A.SETID
        AND C.ITEM_TYPE = A.ITEM_TYPE
        AND ( B.EFFDT =
            (SELECT MAX(B_ED.EFFDT) FROM PS_ITEM_TYPE_TBL B_ED
            WHERE B.SETID = B_ED.SETID
              AND B.ITEM_TYPE = B_ED.ITEM_TYPE
              AND B_ED.EFFDT <= SYSDATE)
         AND A.SETID = 'SOCMP'
         AND B.EFF_STATUS = 'A'
         AND C.EFFDT =
            (SELECT MAX(C_ED.EFFDT) FROM PS_GL_INT_DT_TBL C_ED
            WHERE C.SETID = C_ED.SETID
              AND C.ITEM_TYPE = C_ED.ITEM_TYPE
              AND C.STRM = C_ED.STRM
              AND C.SESSION_CODE = C_ED.SESSION_CODE
              AND C_ED.EFFDT <= SYSDATE)
         AND C.STRM = (SELECT MAX( D.STRM)
      FROM PS_GL_INT_DT_TBL D
      WHERE D.EFFDT =
            (SELECT MAX(D_ED.EFFDT) FROM PS_GL_INT_DT_TBL D_ED
            WHERE D.SETID = D_ED.SETID
              AND D.ITEM_TYPE = D_ED.ITEM_TYPE
              AND D.STRM = D_ED.STRM
              AND D.SESSION_CODE = D_ED.SESSION_CODE
              AND D_ED.EFFDT <= SYSDATE)
         AND D.SETID = C.SETID
         AND D.ITEM_TYPE = C.ITEM_TYPE)
         AND A.SETID = E.SETID
         AND A.ITEM_TYPE = E.ITEM_TYPE
         AND E.EFFDT =
            (SELECT MAX(E_ED.EFFDT) FROM PS_GL_INTERFACE E_ED
            WHERE E.SETID = E_ED.SETID
              AND E.ITEM_TYPE = E_ED.ITEM_TYPE
              AND E.STRM = E_ED.STRM
              AND E.SESSION_CODE = E_ED.SESSION_CODE
              AND E_ED.EFFDT <= SYSDATE)
         AND E.DB_CR_IND = 'D'
         AND E.STRM = C.STRM )) ) Q2
    ON
         Q1."1TEM_TYPE" = Q2."4ITEM_TYPE" LEFT OUTER
    JOIN
        ( SELECT DISTINCT A.STRM AS "2STRM",
        A.ITEM_TYPE AS "2ITEM_TYPE",
        A.DISBURSEMENT_ID AS "2DISB_ID",
        A.OFFER_BALANCE AS "2OFF_BAL",
        A.ACCEPT_BALANCE AS "2ACC_BAL",
        A.DISBURSED_BALANCE AS "2DISB_BAL",
        B.DESCR AS "2ACAD__PLAN",
        A.EMPLID AS "2EMPLID",
        A.ACAD_CAREER AS "2ACAD_CAREER",
        A.AID_YEAR AS "2AID_YEAR",
        A.INSTITUTION AS "2INSTITUTION"
      FROM ((PS_STDNT_AWRD_DISB A LEFT OUTER
    JOIN
         PS_STDNT_FA_TERM C
    ON
         A.EMPLID = C.EMPLID AND A.INSTITUTION = C.INSTITUTION AND A.AID_YEAR = C.AID_YEAR AND A.ACAD_CAREER = C.ACAD_CAREER AND C.STRM = A.STRM AND C.EFFDT =
            (SELECT MAX(C_ED.EFFDT) FROM PS_STDNT_FA_TERM C_ED
            WHERE C.EMPLID = C_ED.EMPLID
              AND C.INSTITUTION = C_ED.INSTITUTION
        AND C.EFFSEQ =
            (SELECT MAX(C_ES.EFFSEQ) FROM PS_STDNT_FA_TERM C_ES
            WHERE C.EMPLID = C_ES.EMPLID
              AND C.INSTITUTION = C_ES.INSTITUTION
              AND C.STRM = C_ES.STRM
              AND C.EFFDT = C_ES.EFFDT) ) LEFT OUTER
    JOIN
         PS_ACAD_PLAN_TB_VW B
    ON
         C.INSTITUTION = B.INSTITUTION AND B.ACAD_PLAN = C.ACAD_PLAN )
         AND A.STRM = '2257'
         AND A.OFFER_BALANCE > 0) ) Q3
    ON
         Q1."1EMPLID" = Q3."2EMPLID" AND  Q1."1ACAD_CAREER" = Q3."2ACAD_CAREER" AND  Q1."1INSTITUTION" = Q3."2INSTITUTION" AND  Q1."1AID_YEAR" = Q3."2AID_YEAR" AND  Q1."1TEM_TYPE" = Q3."2ITEM_TYPE" LEFT OUTER
    JOIN
        ( SELECT DISTINCT A.STRM AS "3STRM",
        A.ITEM_TYPE AS "3ITEM_TYPE",
        A.DISBURSEMENT_ID AS "3DISB_ID",
        A.OFFER_BALANCE AS "3OFF_BAL",
        A.ACCEPT_BALANCE AS "3ACC_BAL",
        A.DISBURSED_BALANCE AS "3DISB_BAL",
        B.DESCR AS "3ACAD_PLAN",
        A.EMPLID AS "3EMPLID",
        A.ACAD_CAREER AS "3ACAD_CAREER",
        A.AID_YEAR AS "3AID_YEAR",
        A.INSTITUTION AS "3INSTITUTION"
    JOIN
         PS_STDNT_FA_TERM C
    ON
        AND C.EFFSEQ =
    JOIN
    ON
         AND A.STRM = '2263'
         AND A.OFFER_BALANCE > 0) ) Q4
    ON
         Q1."1EMPLID" = Q4."3EMPLID" AND  Q1."1ACAD_CAREER" = Q4."3ACAD_CAREER" AND  Q1."1INSTITUTION" = Q4."3INSTITUTION" AND  Q1."1AID_YEAR" = Q4."3AID_YEAR" AND  Q1."1TEM_TYPE" = Q4."3ITEM_TYPE"
    ORDER BY Q1."1NAME" ASC
    Actions
    Query Selected Collapsible section Query Selected
    Query Fields
    Expand Query Name : SSU_FA_CPQ_SCHOLAR_ALL_1 Q1
    Menu
    Expand Query Name : SSU_FA_CPQ_SCHOLAR_ALL_4 Q2
    Menu
    Expand Query Name : SSU_FA_CPQ_SCHOLAR_ALL_2 Q3
    Menu
    Expand Query Name : SSU_FA_CPQ_SCHOLAR_ALL_3 Q4
    Menu
    Susan Gutierrez
  • 9.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-10-2025 07:46 PM
    Susan,
    Does your Composite Query need to show each disbursement for a term or can you do a sum per term?
  • 10.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-11-2025 10:26 AM
    It would be fine to sum the disbursements for each term. So far, I have tried two methods...
    Method #1: I tried creating an expression for each of the term amount fields (Offered, Accepted, Disbursed) and using those in the Fields instead of the term amount fields, which resulted in just one row for the student's scholarship (yay!) but the amounts are double what they should be.
    The expression looks like this (and I had to choose Aggregate Sum in the field properties):
    I didn't save the SQL from Method 1, but I could recreate that and include it in another post if that would help.
    Method #2: Instead of using the expressions in the Fields, I tried choosing Aggregate Sum in the field properties for each of the term amount fields, and again I got one row for the student's scholarship but the term amounts were doubled.
    (I also tried taking the fields from FA Term for Academic Plan and Career out of the Fields, but the term amounts still doubled.)
    Here is the SQL for Method 2:
        Q1."1NAME",
        Q1."1EMAIL_ADDR",
        Q1."1TEM_TYPE",
        Q2."4IT_DESCR",
        Q2."4FUND_CODE",
        Q2."4DEPTID",
        Q1."1OFF_AMT",
        Q1."1ACC_AMT",
        Q1."1DISB_AMT",
        SUM(Q3."2OFF_BAL"),
        SUM(Q3."2ACC_BAL"),
        SUM(Q3."2DISB_BAL"),
        Q3."2ACAD__PLAN",
        Q3."2ACAD_CAREER",
        SUM(Q4."3OFF_BAL"),
        SUM(Q4."3ACC_BAL"),
        SUM(Q4."3DISB_BAL"),
        Q4."3ACAD_PLAN",
        Q4."3ACAD_CAREER"
    FROM
        B.NAME AS "1NAME",
        A.OFFER_AMOUNT AS "1OFF_AMT",
        A.ACCEPT_AMOUNT AS "1ACC_AMT",
        A.DISBURSED_AMOUNT AS "1DISB_AMT",
    JOIN
         PS_SCC_EMAIL_QVW C
    ON
    JOIN
        C.STRM AS "4STRM",
        PS_ITEM_TYPE_TBL B,
        PS_GL_INT_DT_TBL C,
        PS_GL_INTERFACE E
        AND ( B.EFFDT =
         AND C.EFFDT =
      WHERE D.EFFDT =
         AND E.EFFDT =
    ON
    JOIN
    JOIN
         PS_STDNT_FA_TERM C
    ON
        AND C.EFFSEQ =
    JOIN
    ON
         AND A.STRM = '2257'
    ON
    JOIN
    JOIN
         PS_STDNT_FA_TERM C
    ON
        AND C.EFFSEQ =
    JOIN
    ON
         AND A.STRM = '2263'
    ON
    GROUP BY  Q1."1EMPLID",
        Q1."1NAME",
        Q1."1EMAIL_ADDR",
        Q1."1TEM_TYPE",
        Q2."4IT_DESCR",
        Q2."4FUND_CODE",
        Q2."4DEPTID",
        Q1."1OFF_AMT",
        Q1."1ACC_AMT",
        Q1."1DISB_AMT",
        Q3."2ACAD_CAREER",
        Q3."2ACAD__PLAN",
        Q4."3ACAD_PLAN",
        Q4."3ACAD_CAREER"
    Actions
    Query Fields
    Menu
    Menu
    Menu
    Menu
    Expressions Collapsible section Expressions
    Susan Gutierrez
  • 11.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-13-2025 02:51 PM
    I was able to avoid the duplicate rows by taking Disbursement ID out of the child queries and using an expression in the child queries to sum the disbursements per item type.
    Thanks for the help!
    Susan
    Susan Gutierrez
  • 12.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-13-2025 03:03 PM
    Susan,
    I was about to message you today that the best bet is to take care of the multiplying values in the base queries rather than at the Composite Query level.  Seems you beat me to it! Kudos.  When joining to other tables that may have multiple rows per student, it can multiply those sums.
    I too have an expression that @Jeffrie Brooks came up with to handle that.  I almost use it be default now.  I am attaching a small write up I have of it.
  • 13.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 10-14-2025 11:07 AM
    Thank you and Jeffrie for the resource!
    My scholarship coordinator said, "This is beautiful," when she saw the composite query results without duplicates and with AY, Fall, and Spring values all in one row.
    Susan
    Susan Gutierrez
  • 14.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 21 days ago
    Am I understanding that if we schedule a composite query and choose "File" as the output type, there is no text or csv format available?
    Susan Gutierrez
  • 15.  RE: Follow Up to "Using Composite Query - Demonstration and Discussion" (07/30/2025)
    Posted 20 days ago
    Hey Susan - Yes, your understanding is correct.  (Or, at least in my experience it is correct.)  If you select File as the output, the only format is an Excel spreadsheet.  I'm not sure if that is due to a configuration, or if that is just the way the process was designed.
    It would be great to have a .csv option, since this would allow this process to be used more like an extract, with the output file ready to be consumed by whatever process.
    If anyone knows anything additional about this, let us know, please.  :-)
