  • 1.  Need fix for IDs in Multiple Sessions in NSC enrollment reporting
    Posted 05-29-2026 09:25 AM
    We have academic programs that offer multiple sessions now within a term. The NSC report is delivering two profiles for one student.  NSC is rejecting the report and we have reviewed every setup table.  Does anyone have a solution?  The students are only enrolled in one academic program.  Help!
    Kim Carmen
    Registrar LSUSH
    LSU Health Sciences Center
  • 2.  RE: Need fix for IDs in Multiple Sessions in NSC enrollment reporting
    Posted 06-05-2026 02:45 PM
    Hi Carmen! Are you still having this issue? I assume you're using the report generated by PeopleSoft's delivered NSC report via its Consolidate Academic Statistics Process? Can you clarify what you mean by two "profiles"--are you referring to duplicate records for the same student identifier? When you say that the Clearinghouse is "rejecting the report", do you mean the entire file, or just individual student rows impacted by the multiple sessions issue? If the former, what is the reason given by the analyst at the Clearinghouse for the entire file being rejected? As far as I can tell from my review of the Error Resolution Report Guide, only the duplicate records should be dropped (for security reasons)... I believe the PeopleSoft NSC report should be able to account for multiple sessions without producing duplicate campus-level records, so any more details you could provide here would be informative.
    Hope you get this resolved soon if you haven't already! These kinds of "black box" quirks of the PeopleSoft process are one of the main reasons we've recently switched away from using that process to an in-house one that generates the report from queried data, which has been very useful for us since everything is transparent and derived from our own institution-specific logic implemented in our program. I'd be curious to know if others are experiencing the issue you're describing or if it's specific to some idiosyncrasy of your system.
    Robert
    Robert Lang
    Business Systems Analyst
  • 3.  RE: Need fix for IDs in Multiple Sessions in NSC enrollment reporting
    Posted 06-23-2026 05:07 PM
    Yes the report is duplicating the student's enrollment for separate sessions within a term for the final NSC file.  For example, student A is enrolled in both AP1 and AP2 Summer sessions; the NSC report is showing both records instead of just one combined record.  I just don't know where within the setup to correct this error on the file we import to NSC.
    Kim Carmen, M.Ed.
    University Registrar and Notary Public
    LSU Health Shreveport
    1501 Kings Hwy
    Shreveport, LA  71103
    Office: 318.675.5207
    Email: kimberly.carmen@lsuhs.edu
    www.lsuhs.edu
  • 4.  RE: Need fix for IDs in Multiple Sessions in NSC enrollment reporting
    Posted 06-24-2026 12:12 PM
    I think we had this issue before: the student had an ITIN and an SSN, and both were marked as primary.  I know PS doesn't allow this, but I think a file import caused it.  Here is the SQL to find these:
  • 5.  RE: Need fix for IDs in Multiple Sessions in NSC enrollment reporting
    Posted 06-24-2026 03:54 PM
    Edited by Robert Lang 06-24-2026 05:09 PM
    Hi Kim,
    Thanks for that clarification. I'm wondering if we can diagnose the issue as coming from the setup of the Consolidate Academic Statistics process (i.e., in the configuration of academic statistics periods, typically defined by a list of distinct term/career combinations) or from the setup of the NSC enrollment extract (e.g., some customization being applied after the consolidate statistics process...). When you query the EMPLID of a student duplicated on the NSC report from the Student Consolidated Stats record (STDNT_CONS_STAT), selecting ACAD_STATS_PERIOD, are you seeing multiple rows per EMPLID and ACAD_STATS_PERIOD? If you bring in all fields from the STDNT_CONS_STAT record, do any of the fields vary across these multiple rows, particularly any that might explain the duplication issue as it might relate to the multiple sessions? For instance, do Career (ACAD_CAREER) or term (STRM) vary across these rows for the same ID and stats period? What about TERM_TYPE? You said it's different sessions within the same program, so I'm assuming the career is the same and there's not some issue with the career or program primacy setup... but perhaps a session was set up at the same level as the term (i.e., as a statistics period key)? Or you could write a super quick query that selects fields of interest (e.g., career, term, etc.) using the DISTINCT keyword to see the general setup without bringing in individual student IDs, like the following:
    If there are no duplicate rows for a given stats period, career, and term, then the problem is most likely occurring in the generation of the NSC report itself, and you may want to investigate whether your technical team had modified anything related to the NSC extract process (SRNSLCEX.SQR) or the consolidate academic statistics setup (SRPCCONP) for that matter.
    If you DO see multiple rows per student per statistics period, or multiple rows per student per term, you can look at how the statistics periods are defined (navigation: Records and Enrollment
    Enrollment Reporting àConsolidated Statistics àDefine Statistics Period).
    Hope this helps!
    Robert
    Robert Lang
