  • 1.  PERSONAL_DATA: need mapping to source-fields/records
    Posted 11-24-2025 10:38 AM
    Does anyone have documentation, or method for discovering/documenting how and where each field in the PERSONAL_DATA record in Oracle HCM is sourced, without guessing?
    Oracle indicates that PERSONAL_DATA is not (or at least is no longer) a parent-record itself. Rather, it is a "transaction record", i.e. an Oracle-delivered "view record" that is updated by a process. All of the fields are thus mapped back to actual parent-records.
    I NEED THAT MAPPING.
    While I no longer use PERSONAL_DATA in my queries, others do. I need to document exactly what data one of those queries is returning.
    Thanks for your help,
    Senior Data Analyst - Human Resource Information Systems
  • 2.  RE: PERSONAL_DATA: need mapping to source-fields/records
    Posted 11-25-2025 03:36 PM
    I don't have mapping for you, but PERSONAL_DATA is populated by application engine PERS_REFRESH, at least on the Campus Solutions side. I imagine it's the same in HCM. We run that refresh on a daily recurrence. If you don't have app designer access, a developer at your institution may be able to help you understand the logic behind it. My recollection is that it's a fairly complicated program, but it's been a while since I've looked at it.
    Scott Douglas
    Sr. Business Systems Analyst, Student Information Systems
  • 3.  RE: PERSONAL_DATA: need mapping to source-fields/records
    Posted 11-25-2025 04:43 PM
    Thanks Scott.
    The Oracle docs don't indicate whether there is a difference between HCM and CS when it comes to the PERS_REFRESH app engine. My assumption is that they are the same.
    The Oracle docs also don't mention if PERS_REFRESH is configurable. I was assuming it wasn't and that the field mapping would be the same for all institutions.
    Can anyone offer additional insight?
  • 4.  RE: PERSONAL_DATA: need mapping to source-fields/records
    Posted 11-26-2025 08:24 AM
    This goes way back and I don't recall the circumstances, but we run HR_PERSDATA nightly to refresh PERSONAL_DATA. There seems to be some conflicting KBs in Oracle Support related to PERS_REFRESH, but this one indicates that PERS_REFRESH should only be run during upgrades, installs or data corruption, or when changing PERSONAL_DATA settings, and that HR_PERSDATA is the one to run on a regular schedule.
    Oracle Support Document 1543954.1 (When Should the PERS_REFRESH Application Engine be Run? How is it different from the HR_PERSDATA process ?) can be found at: https://support.oracle.com/epmos/faces/DocumentDisplay?id=1543954.1
    Not sure if this is still the case with PERS_REFRESH, but it used to delete all data in PERSONAL_DATA and rebuild it. We did have an issue once when we were still running this process, where it did just that but encountered an error and left PERSONAL_DATA unpopulated, causing several issues. That may be what lead us to switching to HR_PERSDATA now that I think of it.
    Bob Treloar
    Student Systems Team Manager
    University of Pittsburgh
  • 5.  RE: PERSONAL_DATA: need mapping to source-fields/records
    Posted 12-01-2025 10:20 AM
    Edited by Khaliq Bandagi 12-01-2025 10:21 AM
    Hi Scott,
    I was recently troubleshooting why PERS_REFRESH never populated a specific employee data and found the following peoplecode that populates PERSONAL_DATA record in HR. This will give you some insights.
    method UpdatePersonalData
       /+ &EMPLID as String +/
       Local date &DTCHK;
       Local Record &Rec_INSTALL_PERSON;
       Local Rowset &PER_RS, &NAME_RS, &ADDRH_rS, &ADDRO_RS, &PDE_RS, &USF_rS;
       Local Rowset &CAN_RS, &ESP_RS, &DEU_RS, &SA_RS, &USA_RS, &JPN_RS, &ITA_RS, &FRA_RS;
       Local Rowset &PD_RS, &PP_RS, &SMOK_RS;
       Local Record &PER_REC, &NAME_REC, &ADDRH_REC, &ADDRO_REC, &PDE_REC, &USF_REC;
       Local Record &CAN_REC, &ESP_REC, &DEU_REC, &SA_REC, &USA_REC, &JPN_REC, &ITA_REC, &FRA_REC;
       Local Record &PD_REC, &PP_REC, &SMOK_REC;
       If &Rec_INSTALL_PERSON = Null Then
    &Rec_INSTALL_PERSON = CreateRecord(Record.PERSON_DT_SETUP);
    &Rec_INSTALL_PERSON.SelectByKey();
       End-If;
       /* Delete the current entry in PS_PERSONAL_DATA */
       SQLExec("Delete from PS_PERSONAL_DATA where EMPLID = :1", &EMPLID);
       /* Get the PERSON, NAMES, and PERS_DATA_EFFDT data */
       /* PERSON, NAMES, PERS_DATA_EFFDT always exist  */
    &PER_RS = CreateRowset(Record.PERSON);
    &PER_RS.Fill("where EMPLID = :1", &EMPLID);
    &PER_REC = &PER_RS.GetRow(1).GetRecord(1);
    &NAME_RS = CreateRowset(Record.NAMES);
    &NAME_RS.Fill("Where FILL.EMPLID = :1 and FILL.NAME_TYPE = 'PRI' and FILL.EFFDT = (SELECT MAX(A.EFFDT) FROM PS_NAMES A WHERE A.EMPLID = FILL.EMPLID AND A.NAME_TYPE = FILL.NAME_TYPE AND A.EFFDT <= %datein(:2))", &EMPLID, %Date);
    &NAME_REC = &NAME_RS.GetRow(1).GetRecord(1);
    &DTCHK = %Date;
    &PDE_RS = CreateRowset(Record.PERS_DATA_EFFDT);
    &PDE_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_EFFDT PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2) )", &EMPLID, &DTCHK);
    &PDE_REC = &PDE_RS.GetRow(1).GetRecord(1);
       /* Set the values in PERSONAL_DATA */
    &PD_REC = CreateRecord(Record.PERSONAL_DATA);
    &PD_REC.EMPLID.Value = &EMPLID;
    &PER_REC.CopyFieldsTo(&PD_REC);
    &NAME_REC.CopyFieldsTo(&PD_REC);
    &PDE_REC.CopyFieldsTo(&PD_REC);
       /* Records that do not always exist */
       /*** PERSON_ADDRESS  - Home */
       If All(&Rec_INSTALL_PERSON.ADDRESS_TYPE.Value) Then
    &ADDRH_rS = CreateRowset(Record.PERSON_ADDRESS);
    &ADDRH_rS.Fill("Where EMPLID = :1 and ADDRESS_TYPE = :2 ", &EMPLID, &Rec_INSTALL_PERSON.ADDRESS_TYPE.Value);
    &ADDRH_REC = &ADDRH_rS.GetRow(1).GetRecord(1);
          If All(&ADDRH_REC.EMPLID.Value) Then
    &ADDRH_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /*** PERSON_ADDRESS  - Other */
       If All(&Rec_INSTALL_PERSON.ADDRESS_TYPE_OTH.Value) Then
    &ADDRO_RS = CreateRowset(Record.PD_ADDRESS_VW);
    &ADDRO_RS.Fill("Where EMPLID = :1 and ADDRESS_TYPE = :2 ", &EMPLID, &Rec_INSTALL_PERSON.ADDRESS_TYPE_OTH.Value);
    &ADDRO_REC = &ADDRO_RS.GetRow(1).GetRecord(1);
          If All(&ADDRO_REC.EMPLID.Value) Then
    &ADDRO_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /*** PERSON_PHONE */
       If &Rec_INSTALL_PERSON.PHONE_FLG.Value = "Y" Then
    &PP_RS = CreateRowset(Record.PERSON_PHONE);
    &PP_RS.Fill("Where EMPLID = :1 ", &EMPLID);
    &PP_REC = &PP_RS.GetRow(1).GetRecord(1);
          If All(&PP_REC.EMPLID.Value) Then
    &PP_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /*** PERS_SMOKER */
       If &Rec_INSTALL_PERSON.SMOKER_FLG.Value = "Y" Then
    &SMOK_RS = CreateRowset(Record.PERS_SMOKER_VW);
    &SMOK_RS.Fill("Where EMPLID = :1 ", &EMPLID);
    &SMOK_REC = &SMOK_RS.GetRow(1).GetRecord(1);
          If All(&SMOK_REC.EMPLID.Value) Then
    &SMOK_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /*** Country Extensions */
       If &Rec_INSTALL_PERSON.COUNTRY_FLG.Value = "Y" Then
    &USA_RS = CreateRowset(Record.PERS_DATA_USA);
    &USA_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_USA PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &CAN_RS = CreateRowset(Record.PERS_DATA_CAN);
    &CAN_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_CAN PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &ESP_RS = CreateRowset(Record.PERS_DATA_ESP);
    &ESP_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_ESP PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &DEU_RS = CreateRowset(Record.PERS_DATA_DEU);
    &DEU_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_DEU PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &JPN_RS = CreateRowset(Record.PERS_DATA_JPN);
    &JPN_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_JPN PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &ITA_RS = CreateRowset(Record.PERS_DATA_ITA);
    &ITA_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_ITA PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &FRA_RS = CreateRowset(Record.PERS_DATA_FRA);
    &FRA_RS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_FRA PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &ESP_REC = &ESP_RS.GetRow(1).GetRecord(1);
    &DEU_REC = &DEU_RS.GetRow(1).GetRecord(1);
    &FRA_REC = &FRA_RS.GetRow(1).GetRecord(1);
    &JPN_REC = &JPN_RS.GetRow(1).GetRecord(1);
    &ITA_REC = &ITA_RS.GetRow(1).GetRecord(1);
    &USA_REC = &USA_RS.GetRow(1).GetRecord(1);
    &CAN_REC = &CAN_RS.GetRow(1).GetRecord(1);
          If All(&ESP_REC.EMPLID.Value) Then
    &ESP_REC.CopyFieldsTo(&PD_REC);
          End-If;
          If All(&DEU_REC.EMPLID.Value) Then
    &DEU_REC.CopyFieldsTo(&PD_REC);
          End-If;
          If All(&FRA_REC.EMPLID.Value) Then
    &FRA_REC.CopyFieldsTo(&PD_REC);
          End-If;
          If All(&JPN_REC.EMPLID.Value) Then
    &JPN_REC.CopyFieldsTo(&PD_REC);
          End-If;
          If All(&ITA_REC.EMPLID.Value) Then
    &ITA_REC.CopyFieldsTo(&PD_REC);
          End-If;
          If All(&USA_REC.EMPLID.Value) Then
    &USA_REC.CopyFieldsTo(&PD_REC);
          End-If;
          If All(&CAN_REC.EMPLID.Value) Then
    &CAN_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /** USF Extension */
       If &Rec_INSTALL_PERSON.USF_FLG.Value = "Y" Then
    &USF_rS = CreateRowset(Record.PERS_DATA_USF);
    &USF_rS.Fill("Where EMPLID = :1 and EFFDT = (Select max(EFFDT) from PS_PERS_DATA_USF PDE where PDE.EMPLID = Fill.EMPLID and EFFDT <= %Datein(:2))", &EMPLID, &DTCHK);
    &USF_REC = &USF_rS.GetRow(1).GetRecord(1);
          If All(&USF_REC.EMPLID.Value) Then
    &USF_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /** Campus Solutions Extension */
       If &Rec_INSTALL_PERSON.SA_FLG.Value = "Y" Then
    &SA_RS = CreateRowset(Record.PERSON_SA);
    &SA_RS.Fill("Where EMPLID = :1", &EMPLID);
    &SA_REC = &SA_RS.GetRow(1).GetRecord(1);
          If All(&SA_REC.EMPLID.Value) Then
    &SA_REC.CopyFieldsTo(&PD_REC);
          End-If;
       End-If;
       /* set last update time stamp */
    &PD_REC.LASTUPDDTTM.Value = %Datetime;
       /*  Insert  */
    &PD_REC.Insert();
    end-method;
    Khaliq Bandagi
    PeopleSoft Developer
    Long Island University
