  • 1.  Can Callable SQL call Global Variables in Equations
    Posted 07-01-2025 02:09 PM
    Hi All,
    I am writing an equation which uses callable SQLs to assign different global variables, like Dependency, Marital Status...
    I was wondering if I could leverage those assigned global variables in another callable SQL that would use a CASE statement?  If so, how do you write the SQL to reference the global variables?
    Thanks,
    Danny Zavala
    Daniel Zavala
    Analyst Progammer
    California State University-San Bernardino
  • 2.  RE: Can Callable SQL call Global Variables in Equations
    Posted 07-01-2025 03:11 PM
    Hello Daniel,
    Your called SQL would have :prompt variables in them.  You would then take the global variables you have and convert them to local variables:
    ASSIGN Local Variable <name of local>
                     Global Variable <name of global>
    END ASSIGN
    Then the local variables can be used as parameters kind of like what you equation is doing now.
  • 3.  RE: Can Callable SQL call Global Variables in Equations
    Posted 07-02-2025 11:12 AM
    Thanks Daniel for your response.  Making them a Local Variable from a Global Variable totally worked.  Then making the SQL use the variables like I would for Emplid and Aid_Year.  Below are a couple of screenshots, in case like me, somebody needs some help with this.
    Danny
    Daniel Zavala
    Analyst Progammer
  • 4.  RE: Can Callable SQL call Global Variables in Equations
    Posted 07-02-2025 12:11 PM
    Perhaps this should be a different thread but, out of curiosity, does anyone know, from a performative (speed/processing) standpoint, is it better to test a similar condition in multiple WHEN vs nest CASE statements? i.e.
      WHEN FIELD1 = 1 AND FIELD2 = 1 THEN 1
      WHEN FIELD 1 = 1 AND FIELD2 = 2 THEN 2
    vs
      WHEN FIELD1 = 1 THEN
          WHEN FIELD 2 = 1 THEN 1
          WHEN FIELD 2 = 2 THEN 2
