Good morning Lidia,
I'm not sure if your question was just about criteria for determining what the B.LINE_AMT "type" was for each row (Charge, Payment, Refund), or if it was also about report formatting to match the needs of your vendor. I can't help with the first, as I only work in HCM (on the employee payroll/benefits side of Oracle).
But I can offer some help if your question is about formatting the report for a vendor.
For fields that return a value whose purpose or meaning is determined by another field value (ie. a $$$ amount that corresponds to a specific type of Charge or Earn_Code, etc), where you cannot simply add a "Description" column, you can use the field in a CASE expression and return that expression as a field.
For example:
(CASE
WHEN C.ITEM_TYPE_CD = 'P'
THEN B.LINE_AMT
ELSE ' '
END)
AS Payment
When used as a field, this expression would result in a column titled "Payment" where the $$$ amounts are only payments. You would then create additional expressions where C.ITEM_TYPE_CD was equal to C, R, etc. (assuming that's correct) and use those as fields to create their respective columns. I don't know the SQL for setting the field type or width for an expression since I normally work in PSQuery. But I'm sure someone else in the community can help with that part if you need it.
Hope this helps,
Senior Data Analyst-HRIS, Employee Services
1800 Grant Street, Suite 400
Denver, CO 80203
t 303 860 4200
Scott.Frey@cu.edu
www.cu.edu
Senior Data Analyst - Human Resource Information Systems
Message from the HEUG Marketplace:------------------------------
Find, Review, and Engage with Higher Education-focused solution providers, products, and services using the
HEUG Marketplace.
