Minimum Plan Sequence
  • 1.  Minimum Plan Sequence
    Posted 02-24-2025 11:21 AM
    Hello –
    I'm not sure what I'm missing here, or if I am just having a bad day 😉. Can anyone share how to only return a plan from the ACAD_PLAN table on a student record that has the minimum sequence value? Thanks in advance!
    Rachael Daniel
    Director, Systems & Data Analysis
    Division of Strategic Enrollment Management & Student Success
    University of Wisconsin-Milwaukee
    414-229-4277
    rdaniel@uwm.edu
    My pronouns are she/her/hers
  • 2.  RE: Minimum Plan Sequence
    Posted 02-24-2025 12:43 PM
    Hello Rachel,
    I think you can change the EFFDT criteria to:
    By default it is set to Current Date (EffSeq = Last).
  • 3.  RE: Minimum Plan Sequence
    Posted 02-24-2025 12:51 PM
    Sorry, I should have been more clear. If a student has more than one plan, I want the one where, for this single career number, the PLAN_SEQUENCE is the minimum sequence. The dates there (for declare date or eff date) don't always equate the minimum plan sequence number. For example, I want to return ONLY the ACCBBA2 plan code, because it's the minimum sequence number.
    Rachael Daniel
    414-229-4277
    rdaniel@uwm.edu
  • 4.  RE: Minimum Plan Sequence
    Posted 02-24-2025 01:01 PM
    I think what you are wanting to use is a subquery on PLAN_SEQUENCE.   In the subquery you will do your joins as usual, but will select the PLAN_SEQUENCE field and make that minimum.
  • 5.  RE: Minimum Plan Sequence
    Posted 02-24-2025 01:13 PM
    And every time I try to set that to MIN, I get this. So I'm sure I'm missing something in how I build that out.
    Rachael Daniel
    414-229-4277
    rdaniel@uwm.edu
  • 6.  RE: Minimum Plan Sequence
    Posted 02-24-2025 01:22 PM
    Rachel,
    I built a version using my subquery and did not get the error.    Here the SQL for it:
    SELECT A.emplid,
           A.acad_career,
           A.stdnt_car_nbr,
           To_char(A.effdt, 'YYYY-MM-DD'),
           A.effseq,
           A.acad_plan,
           To_char(A.declare_dt, 'YYYY-MM-DD'),
           A.plan_sequence
    FROM   ps_acad_plan A
    WHERE  ( A.effdt = (SELECT Max(A_ED.effdt)
                        FROM   ps_acad_plan A_ED
                        WHERE  A.emplid = A_ED.emplid
                               AND A.acad_career = A_ED.acad_career
                               AND A.stdnt_car_nbr = A_ED.stdnt_car_nbr
                               AND A_ED.effdt <= sysdate)
             AND A.effseq = (SELECT Max(A_ES.effseq)
                             FROM   ps_acad_plan A_ES
                             WHERE  A.emplid = A_ES.emplid
                                    AND A.acad_career = A_ES.acad_career
                                    AND A.stdnt_car_nbr = A_ES.stdnt_car_nbr
                                    AND A.effdt = A_ES.effdt)
             AND A.plan_sequence = (SELECT Min(B.plan_sequence)
                                    FROM   ps_acad_plan B
                                    WHERE  B.effdt = (SELECT Max(B_ED.effdt)
                                                      FROM   ps_acad_plan B_ED
                                                      WHERE  B.emplid = B_ED.emplid
                                                             AND B.acad_career =
        B_ED.acad_career
                                                             AND B.stdnt_car_nbr =
        B_ED.stdnt_car_nbr
                                                             AND B_ED.effdt <=
        sysdate)
                                           AND B.effseq = (SELECT Max(B_ES.effseq)
                                                           FROM   ps_acad_plan B_ES
                                                           WHERE
                                               B.emplid = B_ES.emplid
                                               AND B.acad_career =
                                                   B_ES.acad_career
                                                   B_ES.stdnt_car_nbr
                                               AND B.effdt = B_ES.effdt)
                                           AND B.emplid = A.emplid
                                           AND B.acad_career = A.acad_career
                                           AND B.stdnt_car_nbr = A.stdnt_car_nbr
                                           AND B.effdt = A.effdt
                                           AND B.effseq = A.effseq) )
    If you need screenshots, I can provide those as well.
  • 7.  RE: Minimum Plan Sequence
    Posted 02-24-2025 03:12 PM
    In case the other SQL doesn't format correctly:
    SELECT
      A.emplid,
      A.acad_career,
      A.stdnt_car_nbr,
      A.effseq,
      A.acad_plan,
      A.plan_sequence
    FROM
      ps_acad_plan A
    WHERE
        A.effdt = (
          SELECT
            Max(A_ED.effdt)
          FROM
            ps_acad_plan A_ED
          WHERE
        AND A.effseq = (
          SELECT
            Max(A_ES.effseq)
          FROM
            ps_acad_plan A_ES
          WHERE
          SELECT
          FROM
            ps_acad_plan B
          WHERE
            B.effdt = (
              SELECT
                Max(B_ED.effdt)
              FROM
                ps_acad_plan B_ED
              WHERE
                AND B.acad_career = B_ED.acad_career
                AND B.stdnt_car_nbr = B_ED.stdnt_car_nbr
                AND B_ED.effdt <= sysdate
            AND B.effseq = (
              SELECT
                Max(B_ES.effseq)
              FROM
                ps_acad_plan B_ES
              WHERE
                AND B.acad_career = B_ES.acad_career
                AND B.stdnt_car_nbr = B_ES.stdnt_car_nbr
  • 8.  RE: Minimum Plan Sequence
    Posted 02-24-2025 01:25 PM
    Hi Rachael,
    That error usually comes from having criteria set in the CRITERIA tab for a field that you have defined as an aggregate. If you look at your CRITERIA tab and see something like this:
    That is not normally allowed. There are a couple of different ways that this usually happens:
    1. Check your expressions for the aggregate flag. If you are using one of the aggregate functions, its important that this flag is checked so that the query knows how to group things properly, and put your criteria in the HAVING clause.
    2. Check your FIELDS tab for any aggregate values. These create hidden errors and the MAX(), MIN(), SUM() etc. values aren't shown in the criteria tab. BUT if you view the SQL, you can see that they are written out in the SQL. Because of this, I tend not to define aggregates in the FIELDS tab, and instead define them in the expressions tab most of the time. This happens more often with Subqueries.
    TL;DR Try to define your MIN() sequence number in an expression and use that as your field returned in the subquery instead of defining the aggregate in the FIELDS tab.
    On Mon, Feb 24, 2025 at 1:13 PM Rachael Daniel via Higher Education User Group <Mail@heug.org> wrote:
    And every time I try to set that to MIN, I get this. So I'm sure I'm missing something in how I build that out. Rachael Daniel ...
    Post New Discussion
    Re: Minimum Plan Sequence
    Reply to Thread
    Feb 24, 2025 1:13 PM
    Rachael Daniel
    Rachael Daniel
    414-229-4277
    rdaniel@uwm.edu
      Reply to Community   Reply to Sender via Email   View Thread   Recommend
    Sent: 2/24/2025 1:01:00 PM
    You are subscribed to "PS Query & SQL" as jedobr@umich.edu. To change your subscriptions, go to My Subscriptions. To remove yourself from this community discussion, you can unsubscribe at any time.
    Alliance 2025 Registration Still Open!
  • 9.  RE: Minimum Plan Sequence
    Posted 02-25-2025 06:10 AM
    Rachel,
    This error will occur when you have criteria on the field that you use in the min aggregation. You probably have something in your sub query criteria on X.PLAN_SEQUENCE. The work around is to create an expression of X.PLAN_SEQUENCE then use as field and edit to Min
    Hope this helps
    Robert Fogarty PMP
    Reporting Team Lead | LionPATH Development and Maintenance Office
  • 10.  RE: Minimum Plan Sequence
    Posted 02-25-2025 07:34 AM
    This field is an aggregate field but is being used in non-having criteria error happens when the field being used in the sub query aggregate is being used in the criteria tab.
    The work around is to create the field as an expression,
    then use the expression as as field from the Expressions Tab
    then apply your aggregation ... you will notice that there is no description now from the Record.Fieldname because it is an expression
    Robert Fogarty PMP
  • 11.  RE: Minimum Plan Sequence
    Posted 02-25-2025 10:11 AM
    To add on to what Robert is saying, you could take this solution a step further and define the aggregate within the expression, instead of doing it at the FIELD tab. So it would look like this:
    I strongly recommend doing it this way, instead of defining aggregates in the FIELD tab. This is because it can get real buggy if you try to use that same field for any criteria in the query later on. It's pretty insidious too, since the only way to really know why the error is happening is to look at the SQL!
    The example below shows what is happens when this error occurs:
    You could say that the PSQuery just isn't having it, when this error occurs... but then your friend will groan and call you a nerd...
    On flip-side, if you were to do the same thing, but instead define the aggregate within the expression (And NOT add the aggregate in the FIELDS tab), PSQuery will be smart enough to write the correct SQL statement and put your aggregated field nicely into the HAVING clause, and no error should be thrown.
    Ultimately, understanding what the heck is going on when working with aggregates is hard, and when PSQuery starts writing the underlying SQL in unexpected ways, it just makes it that much harder.
    Hoping this helps!
    On Tue, Feb 25, 2025 at 7:34 AM Robert Fogarty via Higher Education User Group <Mail@heug.org> wrote:
    This field is an aggregate field but is being used in non-having criteria error happens when the field being used in the sub query aggregate is... -posted to the "PS Query & SQL" group
    Post New Discussion
    Reply to Thread
    Feb 25, 2025 7:34 AM
    Robert Fogarty
    Robert Fogarty PMP
    Sent: 02-24-2025 01:12 PM
  • 12.  RE: Minimum Plan Sequence
    Posted 02-25-2025 10:13 AM
    Thanks everyone, I'm back to back meetings today but will give these a shot tomorrow. I really appreciate everyone's help!
    Rachael Daniel
    414-229-4277
    rdaniel@uwm.edu
  • 13.  RE: Minimum Plan Sequence
    Posted 02-25-2025 11:08 AM
    I've tried these things multiple times, and maybe I'm just way off base and missing things. I've tried in subqueries, not subqueries, all over. I've not been able to only return one row for the student's plan code based on minimum sequence. Thanks for the help anyway, I'm always appreciative of everyone giving their time to reply.
    SELECT DISTINCT A.EMPLID, A.ACAD_CAREER, A.ACAD_PROG, B.ACAD_PLAN
      FROM PS_ACAD_PROG A, PS_ACAD_PLAN B
            (SELECT MAX(A_ED.EFFDT) FROM PS_ACAD_PROG A_ED
            WHERE A.EMPLID = A_ED.EMPLID
              AND A.ACAD_CAREER = A_ED.ACAD_CAREER
              AND A.STDNT_CAR_NBR = A_ED.STDNT_CAR_NBR
        AND A.EFFSEQ =
            (SELECT MAX(A_ES.EFFSEQ) FROM PS_ACAD_PROG A_ES
            WHERE A.EMPLID = A_ES.EMPLID
              AND A.ACAD_CAREER = A_ES.ACAD_CAREER
              AND A.STDNT_CAR_NBR = A_ES.STDNT_CAR_NBR
              AND A.EFFDT = A_ES.EFFDT)
         AND A.ACAD_CAREER = 'UGRD'
         AND A.PROG_STATUS = 'AC'
         AND A.ACAD_PROG = 'LAUG'
         AND A.EMPLID = B.EMPLID
         AND A.ACAD_CAREER = B.ACAD_CAREER
         AND A.STDNT_CAR_NBR = B.STDNT_CAR_NBR
         AND A.EFFSEQ = B.EFFSEQ
         AND B.EFFDT =
            (SELECT MAX(B_ED.EFFDT) FROM PS_ACAD_PLAN B_ED
            WHERE B.EMPLID = B_ED.EMPLID
              AND B.ACAD_CAREER = B_ED.ACAD_CAREER
              AND B.STDNT_CAR_NBR = B_ED.STDNT_CAR_NBR
              AND B_ED.EFFDT <= SYSDATE)
        AND B.EFFSEQ =
            (SELECT MAX(B_ES.EFFSEQ) FROM PS_ACAD_PLAN B_ES
            WHERE B.EMPLID = B_ES.EMPLID
              AND B.ACAD_CAREER = B_ES.ACAD_CAREER
              AND B.STDNT_CAR_NBR = B_ES.STDNT_CAR_NBR
              AND B.EFFDT = B_ES.EFFDT)
         AND EXISTS (SELECT MIN( C.PLAN_SEQUENCE)
      FROM PS_ACAD_PLAN C
      WHERE C.EFFDT =
            (SELECT MAX(C_ED.EFFDT) FROM PS_ACAD_PLAN C_ED
            WHERE C.EMPLID = C_ED.EMPLID
              AND C.ACAD_CAREER = C_ED.ACAD_CAREER
              AND C.STDNT_CAR_NBR = C_ED.STDNT_CAR_NBR
              AND C_ED.EFFDT <= SYSDATE)
        AND C.EFFSEQ =
            (SELECT MAX(C_ES.EFFSEQ) FROM PS_ACAD_PLAN C_ES
            WHERE C.EMPLID = C_ES.EMPLID
              AND C.ACAD_CAREER = C_ES.ACAD_CAREER
              AND C.STDNT_CAR_NBR = C_ES.STDNT_CAR_NBR
              AND C.EFFDT = C_ES.EFFDT)
         AND C.EMPLID = B.EMPLID
         AND C.ACAD_CAREER = B.ACAD_CAREER
         AND C.STDNT_CAR_NBR = B.STDNT_CAR_NBR
         AND C.EFFDT = B.EFFDT
         AND C.EFFSEQ = B.EFFSEQ
         AND C.ACAD_PLAN = B.ACAD_PLAN))
      ORDER BY 1
    Rachael Daniel
    414-229-4277
    rdaniel@uwm.edu
  • 14.  RE: Minimum Plan Sequence
    Posted 02-25-2025 11:16 AM
    i do this sub query all the time successfully ... here is my sub query criteria where I is ACAD_PLAN in the sub query and H is ACAD_PLAN in the Top Level of Query
    Logical
    Expression1
    Condition Type
    Expression 2
      I.EMPLID - Empl ID equal to H.EMPLID - Empl ID
    AND I.ACAD_CAREER - Academic Career equal to H.ACAD_CAREER - Academic Career
    AND I.STDNT_CAR_NBR - Student Career Nbr equal to H.STDNT_CAR_NBR - Student Career Nbr
    AND I.EFFDT - Effective Date equal to H.EFFDT - Effective Date
    AND I.EFFSEQ - Effective Sequence equal to H.EFFSEQ - Effective Sequence
    Select the field and Edit to Min
    rtf12@psu.edu
  • 15.  RE: Minimum Plan Sequence
    Posted 02-25-2025 11:20 AM
    Oh I see what I did, I joined acad_plan to acad_plan, that's why it wasn't working. I knew it was something simple I was missing... Thanks!
    Rachael Daniel
    414-229-4277
    rdaniel@uwm.edu
  • 16.  RE: Minimum Plan Sequence
    Posted 02-25-2025 12:42 PM
    In case this is helpful, for this topic or similar issues I often use a custom sort in place of using a set field like PLAN_SEQUENCE.  I cannot always rely on the MIN plan sequence being wanted in a situation with all the different people and processes updating the CPP.  I write the same subquery mentioned by others in this thread connecting the keys of the ACAD_PLAN record except for the ACAD_PLAN field.  Then write a matching case statement on both the the base query and the subquery.  In my below example, I use both parts of the acad_plan code and the plan type to create a custom order.
     SELECT A.EMPLID, A.ACAD_CAREER, A.ACAD_PROG, B.ACAD_PLAN
      FROM PS_ACAD_PROG A, PS_ACAD_PLAN B, PS_ACAD_PLAN_TBL C
        AND A.EFFSEQ =
         AND B.EFFDT = A.EFFDT
         AND A.ACAD_PROG = 'AC'
         AND B.ACAD_PLAN = C.ACAD_PLAN
         AND C.EFFDT =
            (SELECT MAX(C_ED.EFFDT) FROM PS_ACAD_PLAN_TBL C_ED
            WHERE C.INSTITUTION = C_ED.INSTITUTION
              AND C.ACAD_PLAN = C_ED.ACAD_PLAN
         AND CASE
    WHEN Substr( B.ACAD_PLAN, 3, 3) IN ('10K', 'IND') THEN 2
    WHEN  C.ACAD_PLAN_TYPE IN ('MAJ', 'SS', 'SP', 'HS') THEN 1
    WHEN  C.ACAD_PLAN_TYPE = 'CRT' THEN 3
    WHEN  C.ACAD_PLAN_TYPE = 'MIN' THEN 4
    WHEN  C.ACAD_PLAN_TYPE = 'DE' THEN 5
    ELSE 6 END
    ||  B.PLAN_SEQUENCE = (SELECT MIN(
    WHEN Substr( D.ACAD_PLAN, 3, 3) IN ('10K', 'IND') THEN 2
    WHEN  E.ACAD_PLAN_TYPE IN ('MAJ', 'SS', 'SP', 'HS') THEN 1
    WHEN  E.ACAD_PLAN_TYPE = 'CRT' THEN 3
    WHEN  E.ACAD_PLAN_TYPE = 'MIN' THEN 4
    WHEN  E.ACAD_PLAN_TYPE = 'DE' THEN 5
    ELSE 6 END ||  D.PLAN_SEQUENCE
      FROM PS_ACAD_PLAN D, PS_ACAD_PLAN_TBL E
      WHERE D.EMPLID = B.EMPLID
         AND D.ACAD_CAREER = B.ACAD_CAREER
         AND D.STDNT_CAR_NBR = B.STDNT_CAR_NBR
         AND D.EFFDT = B.EFFDT
         AND D.EFFSEQ = B.EFFSEQ
         AND D.ACAD_PLAN = E.ACAD_PLAN
         AND E.EFFDT =
            (SELECT MAX(E_ED.EFFDT) FROM PS_ACAD_PLAN_TBL E_ED
            WHERE E.INSTITUTION = E_ED.INSTITUTION
              AND E.ACAD_PLAN = E_ED.ACAD_PLAN
              AND E_ED.EFFDT <= SYSDATE)))
    University of California, Berkeley
