Query not returning results
  • 1.  Query not returning results
    Posted 05-27-2025 12:54 PM
    Hello everyone,
    One of my users is reporting that when they run a specific query I just built, they get the "no results found" message. It's odd because we've checked their security and made sure they had access to the tables used in the query and that their row level security is correct but they still don't get results. One of their co-workers who has the same access as them, can view the results.
    Thoughts as to why this particular user isn't able to return results? I'm not sure where else to look.
    JenniferChristensen
    Business Systems & Project Analyst
    San Diego State University
    jlchristensen@sdsu.edu
  • 2.  RE: Query not returning results
    Posted 05-27-2025 12:59 PM
    What's the query SQL?
  • 3.  RE: Query not returning results
    Posted 05-27-2025 01:05 PM
    JenniferChristensen
  • 4.  RE: Query not returning results
    Posted 05-27-2025 01:08 PM
    Could it be related to the OPRID = '100635857'  lines?
    On Tue, May 27, 2025 at 1:04 PM Jennifer Christensen via Higher Education User Group <Mail@heug.org> wrote:
    SELECT DISTINCT A.STRM, CASE WHEN SSR_VB_ENR_STATUS = 'I' THEN 0 WHEN SSR_VB_ENR_STATUS = 'R' THEN CERTIF_VALUE ELSE 0 END, D.SSR_VB_SEQUENCE, F...
    Post New Discussion
    Re: Query not returning results
    Reply to Thread
    May 27, 2025 1:05 PM
    ELSE 0
    END, D.SSR_VB_SEQUENCE, F.ACAD_CAREER, C.CAMPUS, D.SSR_VB_ENR_STATUS, A.EMPLID, G.EXTERNAL_SYSTEM_ID,  H.FIRST_NAME || ' ' || H.LAST_NAME, I.EMAIL_ADDR, J.PHONE, K.TUITION_RES, L.SCC_CAF_ATTR_VAL, Case when  M.SCC_CAF_ATTR_VAL is not null then 'Y' else 'N'
    END, Q.SCC_CAF_ATTR_VAL, CASE WHEN  C.ADMIT_TERM =  A.STRM THEN 'NEW' ELSE 'CONTINUING'
    END, TO_CHAR(B.SUBMITTED_DT,'YYYY-MM-DD'), N.SSR_VB_COMMENTS, O.SSR_VB_COMMENTS, CASE when DESCR254 is not null then 'Y' else 'N' END, TO_CHAR(SYSDATE,'YYYY-MM-DD')
      FROM ((((((PS_CSU_VB_SUMMARY A LEFT OUTER JOIN  PS_SSR_VB_STA_FLD M ON  A.EMPLID = M.EMPLID AND A.INSTITUTION = M.INSTITUTION AND A.STRM = M.STRM ) LEFT OUTER JOIN  PS_SSR_VB_FED_AUD N ON  A.EMPLID = N.EMPLID AND A.INSTITUTION = N.INSTITUTION AND A.STRM = N.STRM AND N.SCC_ROW_UPD_OPRID <> A.EMPLID ) LEFT OUTER JOIN  PS_SSR_VB_FED_AUD O ON  A.EMPLID = O.EMPLID AND A.INSTITUTION = O.INSTITUTION AND A.STRM = O.STRM AND O.SCC_ROW_UPD_OPRID = A.EMPLID ) LEFT OUTER JOIN  PS_CSU_VB_ATCH_VW2 P ON  A.EMPLID = P.EMPLID AND A.STRM = P.STRM ) LEFT OUTER JOIN  PS_SSR_VB_FED_FLD L ON  A.EMPLID = L.EMPLID AND A.STRM = L.STRM AND L.SCC_CAF_ATTRIB_NM = 'CSU_VA_BENEFITS' AND L.SCC_CAF_ATTRIB_NM <> 'NONE' AND L.SCC_CAF_ATTR_VAL <> 'NONE' ) LEFT OUTER JOIN  PS_SSR_VB_FED_FLD Q ON  A.EMPLID = Q.EMPLID AND Q.STRM = DECODE(SUBSTR( A.STRM,4,1),'7',  A.STRM-2,'5',  A.STRM-2,'3',  A.STRM-6) AND Q.SCC_CAF_ATTRIB_NM = 'CSU_VA_BENEFITS' AND Q.SCC_CAF_ATTRIB_NM <> 'NONE' AND Q.SCC_CAF_ATTR_VAL <> 'NONE' ), PS_CSU_VB_SSS_INFO B, PS_ACAD_PROG C, PS_SSR_VB_ENRL_HDR D, PS_SSR_VB_ENRL_DTL F, PS_EXTERNAL_SYSTEM G, PS_NAMES H, PS_EMAIL_ADDRESSES I, PS_PERSONAL_PHONE J, PS_RESIDENCY_OFF K, PS_PERALL_SEC_QRY H1, PS_PERALL_SEC_QRY I1, PS_PERALL_SEC_QRY J1
      WHERE ( H.EMPLID = H1.EMPLID
        AND H1.OPRID = '100635857'
        AND I.EMPLID = I1.EMPLID
        AND I1.OPRID = '100635857'
        AND J.EMPLID = J1.EMPLID
        AND J1.OPRID = '100635857'
        AND ( A.STRM = :1
         AND A.EMPLID = B.EMPLID
         AND A.INSTITUTION = B.INSTITUTION
         AND A.STRM = B.STRM
         AND B.SUBMITTED = 'Y'
         AND A.EMPLID = C.EMPLID
         AND A.INSTITUTION = C.INSTITUTION
         AND C.EFFDT =
            (SELECT MAX(C_ED.EFFDT) FROM PS_ACAD_PROG C_ED
            WHERE C.EMPLID = C_ED.EMPLID
              AND C.ACAD_CAREER = C_ED.ACAD_CAREER
              AND C.STDNT_CAR_NBR = C_ED.STDNT_CAR_NBR
              AND C_ED.EFFDT <= SYSDATE)
        AND C.EFFSEQ =
            (SELECT MAX(C_ES.EFFSEQ) FROM PS_ACAD_PROG C_ES
            WHERE C.EMPLID = C_ES.EMPLID
              AND C.ACAD_CAREER = C_ES.ACAD_CAREER
              AND C.STDNT_CAR_NBR = C_ES.STDNT_CAR_NBR
              AND C.EFFDT = C_ES.EFFDT)
         AND C.PROG_STATUS = 'AC'
         AND C.CAMPUS <> 'IVC'
         AND A.EMPLID = D.EMPLID
         AND A.INSTITUTION = D.INSTITUTION
         AND A.STRM = D.STRM
         AND D.SSR_VB_SEQUENCE = (SELECT MAX( E.SSR_VB_SEQUENCE)
      FROM PS_SSR_VB_ENRL_HDR E
      WHERE E.EMPLID = D.EMPLID
         AND E.STRM = A.STRM)
         AND D.EMPLID = F.EMPLID
         AND D.INSTITUTION = F.INSTITUTION
         AND D.STRM = F.STRM
         AND D.SSR_VB_SEQUENCE = F.SSR_VB_SEQUENCE
         AND A.EMPLID = G.EMPLID
         AND G.EFFDT =
            (SELECT MAX(G_ED.EFFDT) FROM PS_EXTERNAL_SYSTEM G_ED
            WHERE G.EMPLID = G_ED.EMPLID
              AND G.EXTERNAL_SYSTEM = G_ED.EXTERNAL_SYSTEM
              AND G_ED.EFFDT <= SYSDATE)
         AND G.EXTERNAL_SYSTEM = 'RED'
         AND A.EMPLID = H.EMPLID
         AND H.EFFDT =
            (SELECT MAX(H_ED.EFFDT) FROM PS_NAMES H_ED
            WHERE H.EMPLID = H_ED.EMPLID
              AND H.NAME_TYPE = H_ED.NAME_TYPE
              AND H_ED.EFFDT <= SYSDATE)
         AND H.NAME_TYPE = 'PRI'
         AND A.EMPLID = I.EMPLID
         AND I.E_ADDR_TYPE = 'OCMP'
         AND A.EMPLID = J.EMPLID
         AND J.PREF_PHONE_FLAG = 'Y'
         AND F.EMPLID = K.EMPLID
         AND F.INSTITUTION = K.INSTITUTION
         AND F.ACAD_CAREER = K.ACAD_CAREER
         AND C.ACAD_PROG = F.ACAD_PROG_PRIMARY
         AND K.EFFECTIVE_TERM = (SELECT MAX( R.EFFECTIVE_TERM)
      FROM PS_RESIDENCY_OFF R
      WHERE R.EMPLID = F.EMPLID
         AND R.ACAD_CAREER = F.ACAD_CAREER) ))
      ORDER BY 17 DESC
    JenniferChristensen
      Reply to Community   Reply to Sender via Email   View Thread   Recommend
    Sent: 05-27-2025 12:58 PM
    You are subscribed to "PS Query & SQL" as jedobr@umich.edu. To change your subscriptions, go to My Subscriptions. To remove yourself from this community discussion, you can unsubscribe at any time.
    Alliance 2025 Session Recordings are Available! Purchase On-Demand Access Now
  • 5.  RE: Query not returning results
    Posted 05-27-2025 01:13 PM
    Names, Email_Addresses, and Personal_Phone all have SACR security.  The user must be missing in the perall_sec_qry table.
           ps_names H,
           ps_email_addresses I,
           ps_personal_phone J,
           ps_residency_off K,
           ps_perall_sec_qry H1,
           ps_perall_sec_qry I1,
           ps_perall_sec_qry J1
    WHERE  ( H.emplid = H1.emplid
             AND H1.oprid = '100635857'
             AND I.emplid = I1.emplid
             AND I1.oprid = '100635857'
             AND J.emplid = J1.emplid
             AND J1.oprid = '100635857'
             AND ( A.strm = :1
  • 6.  RE: Query not returning results
    Best Answer
    Posted 05-27-2025 01:21 PM
    For this reason, it's often better to use the query views when retrieving this data. For example: SCC_NAMES_QVW (or SCC_PRI_NAME_VW... I like that one even better), SCC_EMAIL_QVW, SCC_PERS_PH_QVW, etc. These generally bypass the row-level security rules and include EFFDT logic to retrieve the current row, so they help neaten up the SQL.
    Timothy Krug
    Consulting Manager
  • 7.  RE: Query not returning results
    Posted 05-27-2025 01:32 PM
    I couple of things I see that may or may not be an issue:
    ELSE 0
    In that case statement the fields do not have a record alias.   In other words, should SSR_VB_ENR_STATUS be D.SSR_VB_ENR_STATUS?
    Jeffrie Brooks got me thinking with his response. You are hardcoding in an OPRID.  Is that the OPRID of the user running the query? If not, then you will get no results since if the Query Type is set to USER, PeopleSoft is going to try to add the OPRID of the person running the query and still have the OPRID of the hardcoded.  This would be an "and" boolean operator and would for example be looking for the OPRID to be the value of the person running the query AND the OPRID that is hardcoded.
  • 8.  RE: Query not returning results
    Posted 05-27-2025 01:35 PM
    She didn't hard code the OPRID, PS Query auto adds it with certain tables.  I see it with admissions tables all the time.  And run control tables.
  • 9.  RE: Query not returning results
    Posted 05-27-2025 04:41 PM
    Thanks Tim! I've updated the records on my query per your suggesting and am having the user try to re-run it. Fingers crossed!
    JenniferChristensen
  • 10.  RE: Query not returning results
    Posted 05-28-2025 06:32 AM
    Hey All.  Like Tim indicates, using the SCC_XXX query views is a good practice for returning consistent results when writing queries for a number of reasons, including the reasons Tim outlines.   Below is a list of the tables I am aware of for use in Campus Solutions.  I have uploaded this list to the PS Query & SQL Resource Library.  It can be found here, if you want it in Excel format.
    Cheers!
    Recname  Description
    SCC_ACCOMP_QVW Accomplishments Query View
    SCC_ACCOM_D_QVW Accommodation Diagnosis Query View
    SCC_ACCOM_O_QVW Accommodation Options Query View
    SCC_ACCOM_R_QVW Accommodation Request Query View
    SCC_ACCOM_T_QVW Accommodation Tasks Query View
    SCC_AUDIO_T_QVW Audiometric Exams Query View
    SCC_CITIZEN_QVW Citizenship Query View
    SCC_CITZN_P_QVW Passport Data Query View
    SCC_DISABLE_QVW Disability Query View
    SCC_DIVERS_QVW Diversity Query View
    SCC_DIV_ETH_QVW Ethnic Diversity Query View
    SCC_DRIVERS_QVW Driver's License Query View
    SCC_EMAIL_QVW Email Addresses Query View
    SCC_EMERG_C_QVW Emergency Contacts Query View
    SCC_EMERG_P_QVW Emergency Cntct-Phone Quer View
    SCC_EYE_EXA_QVW Eye Exams Query View
    SCC_NAMES_QVW Person Names Query View
    SCC_PDE_CAN_QVW CAN Person Ext Query View
    SCC_PDE_USA_QVW USA Person Ext Query View
    SCC_PERDATA_QVW PERSONAL_DATA Query View
    SCC_PERS_NI_QVW Person National ID Query View
    SCC_PERS_PH_QVW Phone Numbers Query View
    SCC_PER_EFF_QVW Eff Dated Person Data Query View
    SCC_PHYS_EX_QVW Physical Exams Query View
    SCC_PUBLICA_QVW Publications Query View
    SCC_RESP_EX_QVW Respiratory Exams Query View
    SCC_VISA_P_QVW Visa Data Query View
    SCC_VISA_S_QVW Visa Support Docs Query View
  • 11.  RE: Query not returning results
    Posted 05-28-2025 09:07 AM
    Timothy and Tom,
    Thank you for sharing! this is very helpful.
    Mital Naik
    UT Arlington
  • 12.  RE: Query not returning results
    Posted 05-28-2025 12:48 PM
    If a query view isn't available for an OPRID security restricted record, you can change the query from a User query type to a process query type in the query properties.  This removes those automatically added security joins at the cost of making the query slightly harder to find in query viewer/manager as query type defaults to User for most users on the search.
    I'll also add that, if a user doesn't have security to the underlying records, then the query won't appear in the search results, so if they can find the query, you can rule query tree security out right away.
  • 13.  RE: Query not returning results
    Posted 05-29-2025 11:21 AM
    Thank you Tom and thanks to everyone for the insight!
    JenniferChristensen
  • 14.  RE: Query not returning results
    Posted 05-27-2025 01:30 PM
    Thanks for sharing this! I had no idea.
