Does anyone know what the record is if I wanted to query the prompts that are used for a query on a pop select run control. I think the answer is going to be "it depends on the run control", but I'm optimistically hoping that it is a single record for every one :).
Specifically, I'm looking for the User Edit Message Process ( Financial Aid > Disbursement > Process User Edit Messages). I have this thing running 20+ times to add/update values based on the same query, but different prompt values and I want a query to make sure I've entered all the fields correctly. I know the table names for the run control (SFA_RUN_EDITMSG and SFA_RUN_EDMSOVR), but all the traditional ways that I use to find the table name for query prompts are failing me.
Scott Cho
