  • 1.  Reporting out Run Control Values for a User
    Posted 03-13-2026 08:29 AM
    Good Morning All.
    I am attempting to create a method to review Run Control values for a person who is now on LOA.  She has been with our institution for over 30 years, she has 100's of RC Values configured, and we are trying to document some of what she has created.
    I know that there are certain dedicated tables that store RC data (like PSPRCSRUNCNTL), and there are a lot of one-off tables.  I also know that HCM, FIN and CS handle this differently.
    Does anyone have a document which describes how you approached this problem? (Or approached a similar situation?) I'm not looking for a single all encompassing solution, but it would be helpful to have a plan of attack that has been previously vetted.
    We have other options to get at this data, plus documentation this person left, but we would prefer to also have a reporting based solution to this issue.
    thank you!
    Alliance 2026 Recordings are here!
  • 2.  RE: Reporting out Run Control Values for a User
    Posted 03-13-2026 08:38 AM
    Hi Tom,
    I think I would try to find all tables that contain both fields, OPRID and RUN_CNTL_ID. From there I would see about creating a large SQL SELECT statement in SQL Developer with a ton of unions and have the criterion just be OPRID = "The person's OPRID" for each record that contains both of those fields.
    It's not sophisticated, but I think it would work! You could pretty easily write the SQL in Excel or by employing help from GPT.
    Best,
  • 3.  RE: Reporting out Run Control Values for a User
    Posted 03-13-2026 08:51 AM
    Tom, I'd start with this, but you have to save it as a process query to not get the extra security added to it.  Or have a DBA run it for you.
    SELECT A.OPRID, A.RUN_CNTL_ID, A.SCCPS_CNTXT_ID, A.BNDNUM, A.FIELDNAME, A.BNDNAME, A.BNDVALUE
      FROM PS_SCCPS_RUN_PARM A
     WHERE A.OPRID = :1
      ORDER BY 2, 5
    Business Enterprise Systems and Technologies
  • 4.  RE: Reporting out Run Control Values for a User
    Posted 03-16-2026 09:28 AM
    What Jeffrie said. You can even build your main query to return your SQL for the individual queries.
    select distinct 'select * from ' ||  A.table_name || ' where OPRID = :1;'
    from all_tab_columns A, all_tab_columns B
    where A.table_name = B.table_name
    and A.column_name = 'OPRID'
    and B.column_name = 'RUN_CNTL_ID'
    and A.table_name not like '%AET'
    and A.table_name not like '%VW'
    and A.table_name not like '%RC'
    and A.table_name not like '%TMP%'
    and A.table_name not like '%BRA'
    and A.table_name not like '%SRCH'
    and A.table_name not like '%TAO%';
    There are probably some other strings you may want to exclude from the "table_name not in" list. Even with this list of exclusions, I got over 2800 rows back, so it's still going to take a while to parse through them. Good luck!
    Erica Simpkins
    Business Systems Analyst, ITS
    University of California-Santa Cruz
    esimpkin@ucsc.edu
