  • 1.  Need help with Callable SQL for Equation Engine
    Posted 10-28-2025 09:19 AM
    I'm trying to do an insert into a UC table.  PS Query select gives me 1398 rows.
    This is the SQL from PS Query.
    SELECT A.INSTITUTION, A.TRNSFR_SRC_ID, A.COMP_SUBJECT_AREA, TO_CHAR(A.EFFDT,'YYYY-MM-DD'), A.TRNSFR_EQVLNCY_CMP, 'RD', 'MC'
      FROM PS_TRNSFR_FROM A
            (SELECT MAX(A_ED.EFFDT) FROM PS_TRNSFR_FROM A_ED
            WHERE A.INSTITUTION = A_ED.INSTITUTION
              AND A.TRNSFR_SRC_ID = A_ED.TRNSFR_SRC_ID
              AND A.COMP_SUBJECT_AREA = A_ED.COMP_SUBJECT_AREA
         AND A.TRNSFR_SRC_ID IN ('16001051','16007436')
         AND NOT EXISTS (SELECT DISTINCT B.TRNSFR_SRC_ID
      FROM PS_UC_TRNCOMP_ATTR B
      WHERE B.EFFDT =
            (SELECT MAX(B_ED.EFFDT) FROM PS_UC_TRNCOMP_ATTR B_ED
            WHERE B.INSTITUTION = B_ED.INSTITUTION
              AND B.TRNSFR_SRC_ID = B_ED.TRNSFR_SRC_ID
              AND B.COMP_SUBJECT_AREA = B_ED.COMP_SUBJECT_AREA
              AND B_ED.EFFDT <= A.EFFDT)
         AND B.TRNSFR_SRC_ID = A.TRNSFR_SRC_ID
         AND B.COMP_SUBJECT_AREA = A.COMP_SUBJECT_AREA
         AND B.TRNSFR_EQVLNCY_CMP = A.TRNSFR_EQVLNCY_CMP))
    I modified it to do the insert into the UC table and it's running with no errors, but not inserting the data.   ???  Do you guys see something that I don't?   I don't use this table, I'm doing it for a friend.   I was able to update the UC table.  Some records existed and they wanted those values changed. That one worked.
    Here is my INSERT.  It's chunking fine.  And I put in a message statement and it's telling me it's inserting 0 rows.  I query the data, nothing is being inserted.  It runs and does nothing.
    INSERT INTO PS_UC_TRNCOMP_ATTR
      (INSTITUTION, TRNSFR_SRC_ID, COMP_SUBJECT_AREA, EFFDT, TRNSFR_EQVLNCY_CMP, CRSE_ATTR, CRSE_ATTR_VALUE)
           A.TRNSFR_SRC_ID,
           A.EFFDT,
           'RD',
           'MC'
      WHERE (A.EFFDT =
      WHERE B.EFFDT =
  • 2.  RE: Need help with Callable SQL for Equation Engine
    Posted 10-28-2025 09:25 AM
    Do you guys think it could be security related?
  • 3.  RE: Need help with Callable SQL for Equation Engine
    Posted 10-28-2025 09:38 AM
    Hello Dana,
    Try the following SQL to see if it does anything (also :
    SELECT
      A.INSTITUTION,
      A.TRNSFR_SRC_ID,
      A.EFFDT,
      'RD',
      'MC'
    WHERE
      A.EFFDT = (
        WHERE A_ED.INSTITUTION       = A.INSTITUTION
          AND A_ED.TRNSFR_SRC_ID     = A.TRNSFR_SRC_ID
          AND A_ED.COMP_SUBJECT_AREA = A.COMP_SUBJECT_AREA
          AND A_ED.EFFDT            <= TRUNC(SYSDATE)
      AND NOT EXISTS (
        SELECT 1
        WHERE B.INSTITUTION          = A.INSTITUTION
          AND B.EFFDT = (
            WHERE B_ED.INSTITUTION       = B.INSTITUTION
              AND B_ED.TRNSFR_SRC_ID     = B.TRNSFR_SRC_ID
              AND B_ED.COMP_SUBJECT_AREA = B.COMP_SUBJECT_AREA
    I noticed that you have a DISTINCT in the DOES NOT EXIST subquery.  In an EXISTS or NOT EXISTS subquery, the database only cares whether at least one row matches the condition (TRUE or FALSE) and never looks at the actual values returned by the SELECT list.  I am not saying that it is the cause of the issue.  How is the equation set up?
  • 4.  RE: Need help with Callable SQL for Equation Engine
    Posted 10-28-2025 09:51 AM
    Thanks, Dan.
    I just got it to work and came back to let you know I was missing DISTINCT.  I had 1 value that was duplicated.
    So I needed SELECT to be SELECT DISTINCT.
  • 5.  RE: Need help with Callable SQL for Equation Engine
    Posted 10-28-2025 10:12 AM
    So you put the DISTINCT on the SELECT in the main part of the SQL?
  • 6.  RE: Need help with Callable SQL for Equation Engine
    Posted 10-28-2025 10:21 AM
    I added it below (highlighted) and then it worked.
    SELECT DISTINCT B.INSTITUTION,
           B.TRNSFR_SRC_ID,
           B.COMP_SUBJECT_AREA,
           B.EFFDT,
           B.TRNSFR_EQVLNCY_CMP,
           'RD',
           'MC'
    FROM PS_TRNSFR_FROM B
      WHERE (B.EFFDT =
            (SELECT MAX(B_ED.EFFDT) FROM PS_TRNSFR_FROM B_ED
              AND B_ED.EFFDT <= SYSDATE)
         AND B.TRNSFR_SRC_ID IN ('16001051','16007436')
         AND NOT EXISTS (SELECT DISTINCT C.TRNSFR_SRC_ID
      FROM PS_UC_TRNCOMP_ATTR C
      WHERE C.EFFDT =
            (SELECT MAX(C_ED.EFFDT) FROM PS_UC_TRNCOMP_ATTR C_ED
            WHERE C.INSTITUTION = C_ED.INSTITUTION
              AND C.TRNSFR_SRC_ID = C_ED.TRNSFR_SRC_ID
              AND C.COMP_SUBJECT_AREA = C_ED.COMP_SUBJECT_AREA
              AND C_ED.EFFDT <= B.EFFDT)
         AND C.TRNSFR_SRC_ID = B.TRNSFR_SRC_ID
         AND C.COMP_SUBJECT_AREA = B.COMP_SUBJECT_AREA
         AND C.TRNSFR_EQVLNCY_CMP = B.TRNSFR_EQVLNCY_CMP))
  • 7.  RE: Need help with Callable SQL for Equation Engine
    Posted 10-30-2025 01:16 PM
    Ah yes, a unique keys error on insert would cause all pending SQL to rollback.  Makes sense why it might fail without and succeed with the DISTINCT.
  • 8.  RE: Need help with Callable SQL for Equation Engine
    I changed my letters (aliases) too.  Changed B to C and A to B just in case it didn't like that the A.
